. . . still way too much on my plate, but things have come together much better than last year's suddenly picture-free thread:
HELP! Noob Building a Parallel Port ROM HackStation . . .
Thanks to a heads up from snake88usa, I picked up a pile of goodies to split with him and managed to snag a Dell Dimension 4100 PIII(?)box with a Win98 SE COA/Serial Number stuck to its removable side panel for $4.00! It's the same case as the Dell DimensionXPS D333 '95 box we ruled out as too slow for '98, IIRC . . . or maybe I just couldn't stomach having a Dell Box under the Bench?
Whatever, this one looks better with its swoopy front air intake vent and a smoochy face Quadra FDD slot. Between the two cases, I've got one with all the internal appointments complete. It had a '98 workable install on the HDD, so I took that out and tried to install my "New Machine" 98 SE Install Set and was told I needed to buy the upgrade version. FEH!
Luckily I'd snagged Hiren's Boot CD when I started the project. Dunno how it works, but the thing booted into MiniXP off the CD and used a freeware overwriting utility to nuke the pestiferous '95 install on the C Drive. < evil >
I've now got a clean, new machine install of Win98 SE using the COA from the side panel instead of the one I bought on an install manual last year. Last night I had it running off the main KVM setup, but the USB (hub?) driver was borked today, go figure. Somewhere I've got a '98 compatible USB2 card stashed away to fix that at some point.
Here's where the help comes in: I'm running '98 in 640x480x4bit on a 1600x1200 LCD and Diplodocus (its name henceforth for various reasons) sits next to the desk underneath a 22" ViewSonic QXVGA/2k CRT Display. So the resolution is badly in need a major overhaul. I never ran '98 in 640x480x4bit back in the day and I'm certainly not about to start doing so now!
I've rummaged through the boxen and there's a Voodoo3 3000 AGP card in there now outputting the same damn res. I've found legacy '98 drivers for it, but no references anywhere to it throwing anything but high frame rates of that same damn 640x480 res at a screen, albeit at higher bit depths. Anybody know if these high end gamer cards supported high resolutions/bit depths as well?
I've got '98 drivers for the ATI Rage Pro 128, but will I need to reverse-flash a Mac Card to run the friggin' thing in a PC if the Voodoo3 doesn't work out?
