Help Me ID This SE Ethernet Card
Hi All,
I recently got this Ethernet card from another member here.  Looks to be in good shape.  Hooking it up to my SE and an active Ethernet cable powers the light on the back of the card with the ports.   :)
However, I'm not sure what model/drivers I need for it.  There doesn't appear to be any branding on it at all.
If anyone happens to know which drivers to try I'd greatly appreciate it.  If not I'll have to go one-by-one down mac-driver-museum's website to try out all the drivers until it hopefully works.
Thanks
That's a Farallon EtherMac SE-C. (PN596-C)
I'm not sure which driver is appropriate, but hopefully that leads you in the right direction.
Thank you so much!!!! it was indeed a Farallon card.
Bad news first:  The download on vintageapple.org is corrupt.  Finding another download was proving difficult.
Good news:  The Ethernet card I ordered for my Color Classic came with a floppy disk "Farallon Ethernet Card LC/PDS."  This driver appears to work and the diagnostic software is seeing the card.  Running the tests, everything checks out okay :)
Thanks again for putting me on the right path. I really appreciate it.
