Hi all, I acquired another SE, an FDHD this time. I pulled the HDD out because it wasn't booting anymore, installed a new drive and system 7.1 from a dead LCII I had, and it runs like a dream now. My problem, such as it is, comes from trying to hook the bad drive up to an external enclosure to see if I can pull some data off of it.
I'm using the guts of an Apple External Hard Drive (M2115) (http://appletothecore.me/files/m2115_external_drive.php), and whenever I turn the thing on it freezes my SE. I can't boot into the internal drive, even after setting it to be the startup disk in control panel. I'm not sure what the issue is, or how to fix it. I was hoping someone could at least point me in the right google direction; my google-fu is weak tonight. I'm pretty sure the enclosure works; with the original disk in it, I was getting SCSI errors from Lido at least.
As an aside, somewhat, I tried to hook my SCSI2SD up to the enclosure, and it's not visible to the SE. Is this to be expected? I would have thought it'd just operate as a HDD, but it doesn't look like it.
I have the SCSI ID of the enclosure set to 4.
I have a ZIP drive that works like a dream, so I know the port is good.
Any additional info that is needed, please ask and I'll do my best to provide the answers.
Thanks in advance!
Thanks in advance!
