Was this just a PB 150 problem? In which case it's another strike against that poor PowerBook. Definitely an odd bird. They make it almost impossible to use it as a desktop replacement by removing the ADB port and second serial port, then, even though they had to burn a new ROM to utilize the IDE bus, they don't add SCSI disk mode code to it, which would make it a perfect companion for use with a desktop. They add a more expensive 640x480 LCD, but limit it to 2-bit grayscale which most applications that needed 640x480 probably couldn't use. Odd.
