Anyone using Ghidra for A/UX executables, how are you doing it? Just extracting the .text/.data sections and importing as raw, or do you have a way to directly load the COFF objects?
Out of the box Ghidra doesn't recognise big-endian COFF, but the patch is an easy fix and at least this gives you the symbols from non-stripped objects. There's no support for A/UX's shared libraries, I guess this would need more work to handle relocations (I don't really understand COFF shlibs, so I have nfi about this). And converting TRAP#0 to decompile to a function call needs knowledge from PAGING/os/sysent.c to correctly handle arguments and then whatever on the Ghidra side to assist the decompiler.
Has anyone tackled this with external support like the mac classic stuff?
