G4 Zip drive question
Quadraman
68030
I just got a bunch of used zip discs for free and some of them won't mount. I can understand if they might be PC format that they wouldn't work, but is there any way I can reformat these discs or at least force my Mac to recognize that they are in the drive? I can't even eject the discs from the desktop, I have to eject them manually.
PC format disks worked in my PM 5500 with an external Zip Plus drive and IomegaWare 6.0.2, so it shouldn't just be because they are PC formatted.
I read PC formatted zip 100 disks in my powermacs just fine (2 beige g3's and 2 B&Ws).
Any chance you stuck a zip 250 disk into a zip 100 drive?
Can't he format it with Drive Setup? Assuming you are booting into 9 or lower.
In OS X it should appear in Disk Utility.
How do you eject the zip discs manually?
There should be a pinhole on it somewhere that you can insert a paperclip into, like a CD/DVD drive. External zips have it on the back.
I pried back the cover on the front of my G4 to expose the eject button underneath. Why Apple obscured the manual eject button like that is beyond all reason.
