G3 iMac 400 power troubleshooting
I've been given a strawberry G3 iMac 400/DV that is nice and clean but won't power up. So far I've replaced PRAM battery and tried pushing the CUDA switch. On one occasion the power-on button flashed for less than a second, but generally nothing fires up. I do hear a pop in the speakers, which suggests there is some power on the board but not enough to boot. Display remains dark.
Any suggestions on a troubleshooting checklist? Could this be a caps issue?
Rick
Yes can be, you can probably find the service manual online, it's pretty well done... will help troubleshooting any issue.
It might be easier (and less labor intensive) to just replace the analog board with a known working pull from another iMac (such as one who's CRT is smashed and/or who's plastics have crumbled.) How you choose to proceet is pretty much up to you, though.
Anyway, however you choose to proceed, I wish you luck!
c
The hard part is cracking it open and getting the PAV board out... Replacing the caps or replacing the board is just a choice...
I found replacing the caps was pretty easy. There are a lot of them, that's true, but hey isn't reviving these macs a fun hobby?
It takes some time, but i found replacing the caps easier then getting the PAV-board out and back in...
To repair or replace is always a fair question, but location is a big factor. I see working G3 iMacs advertised for $5 in California, but in my location to get parts from anywhere adds $40-50 freight to the cost, even for a logic board, and working units are rare locally. Nobody seems to bother parting out G3 iMacs in Australia.
The main risk in starting a major re-cap is that I could get to the end of it and then find the problem was deeper, say a failed PMU/CUDA chip. Anyway, while I wait for a logic board or working iMac to turn up at reasonable cost, I'll disassemble this one and see if I can see any evidence of other probs, before investing in the re-cap.
Rick
Somewhat an identical situation in belgium :)
Keeps us updated! Perhaps you could try the pin-readout I posted?
I'll be following your experience closely, but not necessarily quickly. Yes, I'll report back when I make any progress.
Rick
