Hi everyone,
I picked up this FW800 MDD for $50 thinking it only had power supply issues. I replaced the PSU with a mini ITX power supply through wiring diagrams available online, but to no avail. On boot, I get no chime, no RAM beeps, just fans at full blast after several seconds.
The serial on the rear indicates it's a single CPU G4 at 1GHz, built in Feb. 2003. The CPU I found installed is a dual 867Mhz. There were 3 sticks of PC2700 installed when I got it.
After more digging online, I found that this specific G4 has no CPU upgrade path. I bought a single CPU card at 1GHz hoping to restore the machine.
I installed the card and this changed nothing whatsoever.
I've tried PC2100 memory, PC2700 memory, no memory, different slots, reseating, detaching and reattaching components one at a time - all to no avail.
At this point I can't really identify what combination of logic board and CPU this thing needs to work, or if the logic board itself is even functional. The lack of a startup chime or beeps indicating the absence or incompatibility of the RAM isn't great.
Can anyone confidently identify what logic board I need to compliment either of these CPUs? Firewire 800 isn't essential if it comes down to it.
