So I got this Radius PDS Photobooster. One of the pins was out of alignment. I have put it back. The card is recognised by driver but when using Photoshop filters it freezes the computer. Is anything that can be done to make it work again?
If you have a logic board out of a computer, I'd check continuity between the photobooster and the Quadra.
First find which soldered connection on the photobooster connects to the pin that was bent, then plug it into a board, and see if you can find any pin on the logic board that has continuity. Ideal if the logic board has a through hold PDS connector, I can't remember if they are.
If you have continuity from photobooster to the logic board, I'd check different versions of the drivers, plugins and Photoshop? Perhaps OS too?
Oooh, neat. I hadn't seen that one before. I'd only seen the one that clips directly onto the card. How does it compare to the clip-on version for the GX? Or are you still testing it out?
I especially like how it lines up perfectly with the video card.
