Hello,
Apologies if this post is in the wrong place; I looked around several of the boards but didn't see any hard drive discussion in Peripherals. Links to other relevant discussions most welcome (I did search, but didn't find anything on this precise topic).
I am getting back into vintage mac collecting after a long hiatus (I collected a bunch of stuff about 15 years ago). Among the items gathering dust in my basement were a Mac 512Ke and a Mac Plus (both boot to floppy and are working), along with two external SCSI hard drives, one Cutting Edge, one MacBottom (both HD 20, I believe, though I can't get the CE one to start to find out). The MacBottom SCSI disk does work.
My question is about the CE hard drive, which used to work the last I remember years ago, but now won't mount. It powers up and spins (and makes a lot of noise, probably not good), and the computer behaves as if it is trying to communicate with it (eg the drive spins more at the moments when the computer is trying to talk to it), but no HD image shows up on the desktop when I mount from a floppy, and disk utilities that I have used to try to test or reformat the drive (Apple Disk Utilities, a very old copy of Norton Utilities, the original CE formatting disk) come up with various errors.
If I wanted to open up the enclosure and put a new SCSI hard drive in it to replace the one that may have failed, what brand of internal HD would I need to buy? Alternatively, are there any HD troubleshooting sites out there that I could work through to possibly reformat the malfunctioning drive and try to get it running again?
Any advice re: using external HDs with 68000 Macs generally welcome!
