Extension Manager 3.0.3 & System 7.1.x, not compatible?
Paralel
68020
Has anyone else encountered a problem with getting Extension Manager 3.0.3 to work with System 7.1.x?
Everytime I try to open the control panel is says not enough memory, which isn't possible (nearly 34 MBs free), or that the control panel extension is damaged, which couldn't be true because I expanded it directly from the installation tome in which it was entombed. and I have tried doing so from several sources with the same result.
If I try to call EM 3.0.3 using the space bar at boot it flashes quickly, then disappears, and boot proceeds as usual.
EM B1-3.0 works just fine with System 7.1.x, but what could be causing 3.0.3 to act this way? Going by the version increment, it shouldn't have been much of a change.
