Dynaport Esi/30 problems
Hello,
I've recently acquired an old apple mac Se/30 and decided to face the challenge of getting it onto the internet so I bought a Dynaport Esi/30 Ethernet card and preformed a clean install of 7.5.3 i then bridged the ether connection on my laptop to the WiFi then connected the Se/30 to my laptop and following some guides on the internet attempted to set it up using Mac/TCP with no luck
Then i came across a very helpful guide on this site which recommended the use of open transport, so i updated the mac OS to 7.5.5 but again after another hour of playing around with apple-talk, open-transport and all the other settings and connecting the Se/30 directly to a router nothing happened, so I'm wondering if i need any additional drivers for the Ethernet card , there is a green status light on the back which blinks about 2 flashes a second when a Ethernet cable is connected.
the annoying thing is that when i was playing around with 7.5.3, Mac/TCP and connected to the laptop's bridged connection it did at one point connect to the laptop and the green status light on the Se/30 was solid but i have no idea what i had done to make it connect to the laptop and after restarting the Se/30 the connection was lost.
What am i doing wrong hopefully its something simple and not a duff PDS card.
Thanks in advance for any advice, Josh.
I've run into what sounds like the same issue a handful of times with some (but not all) PDS Ethernet cards I've tried. What ended up yielding success was using a router or switch with manually configurable ports, or using bridged networking on a Mac or PC. The trick was to set the port on the switch, router, or modern computer to 10Base-T rather than auto negotiation. Sometimes this also disables Auto MDI-X and may necessitate use of a crossover cable if connected between computers. Apparently some of the cards I own respond incorrectly to auto negotiation from a modern device, causing it to select an incompatible mode. I did experience brief success intermittently before changing the port setting, but rebooting or disconnectong anything would send me back to frustration. I attributed this to just be a fluke where the PDS card didn't "confuse" the modern device. Hope this gets you going. I can't remember if half vs full duplex makes a difference. Someone also suggested putting a 10Base-T hub or switch between the PDS card and router. Didn't have one to try.
well lock the ethernet port to 10bt half duplex.  and also manual set the ip… lots of these cards have issues accepting dhcp.  I like the Mac Con cards because they just work. :)  just like magic.  most all others do not.
