I read somewhere in this forum that it's possible to transplant the screen from a Duo 230 into PB 100.
Duo 230 Screen
Built-in Display: 9.1" Grayscale Native Resolution: 640x400
Details: 9.1" grayscale passive-matrix (4-bit, 16 grays) Supertwist LCD with a 640x400 native resolution.
PB 100 Screen
Built-in Display: 9.0" Monochrome Native Resolution: 640x400
Details: 9.0" monochrome passive-matrix (1-bit) Supertwist LCD.
Looks like roughly the right size, and resolution is correct, but would this work?
I'm assuming the wiring harness plug would not be compatible.
This would be great if it worked as I have a PB 100 that has pink splotches all over it.
Thanks!!
Duo 230 Screen
PB 100 Screen
Thanks!!
