Dual Boot SSW 6 and 7 on same drive but different partitions?
I know it's possible to do so.
I'd like to dual boot 6.0.8 and 7.0.1 on my SE/30. Maybe even 7.5.5.
I've done so on my Quadra 700, however I was having some troubles. This was done on an SCSI2SD and will be done on one in the SE/30 also.
On my Quadra, I made two partitions, each 500 MB. I installed 7.0.1 on one and 7.6.1 on the other. One was named 7.0.1 and the other... 7.6.1. Now, I restart the machine (Was installed by CD). It boots to 7.0.1. Cool, that works. Now I play around a little, and then switch the startup disk to 7.6.1. But wait, both disks are highlighted in startup disk? I ignored this and selected 7.6.1. Restart. Boots to 7.0.1... again.
I'm going to guess the same issue will happen on my SE/30. First of all, is this even possible? I would assume it is... but secondly, what did I do wrong?
There is probably a way somehow, but I just put all of my system folders on one partition, and then use System Picker to choose between the two of them. It works really well for me.
You should really give system picker a spin. Sure it won't let you put them on different partitions, but it will let you choose which version of SSW you want to boot.
Easier? All you need to do is install the system picker CDEV, (easy to find and use), then copy 7.6.1 to the 7.0.1 partition renaming it system 7.6 so it has a different name then drag and drop. Make sure you pick a SSW in system picker, and you are good to go!
Well easier as in I've got the partitions ready.
I'll try it out if nobody replies! So that's it?
This is what I think your supposed to do
Initialize as one partition
Install 7.0.1
Rename 7.0.1 folder to xxx
Clean install 7.5.5
Rename to xxx (optional)
Install sys picker?
Yes, just make sure you have system picker ready to BEFORE you reboot with the two SSW folders on your computer.
So follow all the instructions up to install 7.5.5
Then use system picker to choose an OS
Then reboot!
Sorry to necropost. Was there ever a utility to prevent System 7 from automatically rebuilding the desktop every time you switch to it from System 6? I seem to recall hearing about this but I can't for the life of me remember what it was called.
