I've got this dual 800k SE with a peculiar floppy issue. Both 800k drives work great when plugged in by themselves to either the upper or lower connector on the mainboard. However, when I connect both up at the same time, the floppy drive connected to the upper connector is very, very, very slow. If I shutdown, disconnect the lower drive, the upper is now normal speed. It doesn't seem to matter which 800k drive is in that position either, it's just always the upper connector when both floppy drives are connected when this occurs. Has anyone seen something like this before?
