That card is a good price, but flashing seems to be a little unreliable with what cards it works with so I can't tell you yes or no sorry. You'll need a new ROM chip because PC cards come with a ROM chip that is too small for the mac firmware.Thanks a lot! So this one might work?
Can I flash it using a Mac (or maybe with a chip programmer)?
Cool! Let's see how it turns out. Plug- and play might be important for me, as I'm planning to use a KVM to share screen and mouse/keyboard with a Mac Mini G4.I can also confirm that a flashed 7000 will happily plug and play with a 23" aluminum cinema display at 1920x1200.
Additional background might be tied to the same issue mentioned in the August 2005 Radeon ROM update documentation.
For the 9000 Pro, 9800 Pro, and 9800 Pro Special Edition, "Fixed hotplug bug with 20", 23", and 30" DVI Apple Cinema Displays" is listed. Unfortunately nothing like that for the 8500 (though not too different from the 9000 Pro, itself.)
In the mode tables section, the doc also mentions "The RADEON card's maximum digital resolution is 1920x1200 (using a reduced blanking interval compatible with Apple's Cinema HD ADC Display, using an Apple or third-party powered adapter)." This isn't directly related to the aluminum models though.
Most other DVI 1920x1200 panels should have better compatibility.
Ok the card arrived, but I wasn't able to flash it with my Powermac 8550. I tried several tools and even installed MacOS 10.3 on it but with no success. The onboard Flash is an AT25F512 so there should be enough space? I haven't got an old PC so can't flash it under DOS. A new 1024K chip is now underway so my next attempt will be to flash the chip directly.Thanks a lot! So this one might work?
The mac firmware updates don't work on PC cards that I know - how were you trying to flash it?Ok the card arrived, but I wasn't able to flash it with my Powermac 8550. I tried several tools and even installed MacOS 10.3 on it but with no success. The onboard Flash is an AT25F512 so there should be enough space? I haven't got an old PC so can't flash it under DOS. A new 1024K chip is now underway so my next attempt will be to flash the chip directly.
Cisco Aironet 340Native WiFi on the 8550
