Display problem on Macintosh Plus
Hello there,
On a a recapped Mac Plus I got this display :
There is also a strong corona discharge noise... I know probably I have to change this transformer.
Is there a possible repair (put epoxy resin inside and so on) ?
But is this moving display problem related also to this transformer ?
Thanks, regards.
Philippe
Does it go away as it warms up? That looks like an issue I had, see here:
Bad solder joint or voltage too low.
using a multimeter at the floppy port is the way to go.
on the side of the Analog Board, a pot is provided for adjusting voltage.
