Hi, sorry for the possibly niche question but I haven't been able to find any info on this problem --
I recently picked up a Mac Plus + HD-20 running System 6.0.8 and just fixed it up with 4MB RAM and installed a Radius Accelerator 16 board (which is awesome, by the way). After that I cleaned up the HD and installed Disinfectant -- and suddenly noticed the system hangs on startup. Pretty quickly I figured out that with the Disinfectant 3.7.1 INIT installed, the system always hangs after loading the last INIT (which isn't necessary Disinfectant) and before the Finder appears. This happens 100% of the time with the Disinfectant INIT installed, and never happens without it.
I tried reinstalling 6.0.8 and deleting the INIT and installing a fresh copy from inside the Disinfectant application. I have NOT tried removing the Radius board because that's a huge pain and frankly I'd rather do without the INIT anyway -- so I don't know yet if things would be fine without it (soon I will set up another old Mac Plus and try the HD-20 without an accelerator and maybe learn something). But I was hoping someone might know of any known incompatibilities (and hopefully a fix?) between some subset of the Disinfectant INIT, the HD-20, and a Radius Accelerator 16? (I've basically never heard of Disinfectant being incompatible with anything, it always seemed to be the perfect-citizen INIT.)
Ideas for a good virus protection alternative also welcome. I have a bunch of old floppies that have been bequeathed to me from various sources and I've found a lot of them have flavors of nVIR/CDEF/WDEF on them. I guess I could just scan the hard drive every so often ...
