I'll write down a few notes on what I did to get pretty decent video capture as it wasn't obvious.
1. DB15 -> VGA. This is well documented.
2. active VGA to HDMI adapter. I used "FOINNEX VGA to HDMI Converter Adapter with Audio 1080P" (https://www.amazon.es/dp/B072NCTBVP?)
3. HDMI capture card, take one with MS2130 chip, I got this one: https://www.amazon.es/dp/B0CL3H7PMF
Make sure to power #2 sufficiently or you won't get anything out.
Make sure to connect 3 using 5GB USB port/cables (or else you will get a USB2 video capture card, and low quality)
What I got up to this point was "ok" but with obvious artifacts. By default it will clip YUV to range [16..235], and the other format (MJPEG) that does not clip is a compressed format and causes the typical low res jpeg artifacts.
Fortunately, folks have hacked the firmware:
4. Flash its firmware: https://github.com/steve-m/ms2130_patcher
git clone https://github.com/BertoldVdb/ms-tools.git
cd ms-tools
go build -o /tmp/ms2130 ./cli
cd ..
make a backup
./cli --log-level=7 read FLASH 0 --filename=backup.bin
then flash:
./cli --log-level=7 --no-patch write-file FLASH 0 ms2130_patched_v1.bin
5. At this step, for me it worked on windows to get a perfect capture (uncompressed, YUV, no clipping) - compared pixel values. On linux I use:
ffplay -f v4l2 -video_size 640x480 -input_format yuyv422 \
-color_range jpeg \
-colorspace smpte170m \
-i /dev/video0
I did not retry on my macbook but should work there too.
cd ms-tools
cd ..
make a backup
then flash:
-color_range jpeg \
-i /dev/video0
