Since I scored some old 68k music software, I put together a very nice condition SE to use it on. So far it works great. The hard drive I am using is a square enclosure which is branded "Cutting Edge". Seems cool enough, I installed 6.0.8 on there and started messing around with my old apps.
But my other Macs are more recent... Much of my other stuff for 68k resides in an archive on my 8600. Easiest thing I thought would be to connect the drive to my 8600 and copy things over. But the 8600 does not want to mount this external drive! It boots fine, and Drive Setup shows it as bus 1 number 1, but when I try to mount it I break into Macsbug: NQDCopyRgn+0004c. I guess this means that it has trouble reading from the drive. Any suggestions? I guess this is caused by some old-style formatting weirdness?
Seems like this would be a far easier route than trying to make old-style floppies in OS 9.1. I will press on and try to find an alternate disk tool, or try mounting a SCSI CD on the SE.
