hi, Im interested in gathering data regarding the issues people have had using custom ROM SIMMs in their Macs. I have been making pcbs and working with using customs roms but I have ran into some intermittent issues around using non apple simms. I would like to gather any information I can regarding things such as the model on Mac used, the Simms used that doesn't work, the ram chip part numbers and speed as well as the thickness of the Simm boards measured at the contact edge using callipers etc. I'm trying to narrow down the reason why some Macs such as the se/30 will work with stock roms and not with custom rom boards. the more details you can provide the better as it seems from my research that using customs boards can be a bit like the lotto in regards to what machines or whatnot they run on.
For example I have a se/30 that without fail will not boot a custom Simm regardless of is a shim is used or not and I have even replaced the socket with a NOS AMP part, yet sometimes if I wait a little bit and hit the reset switch it'll boot fine. however without fail as soon as I swap with a. stock standard apple rom Simm it boots immediately.
any information you can provide I would be most great full for as this has really got me completely stumped, while I don't have a second se/30 of a different revision to example/work with perhaps its just my machine though I have heard/read on the web that many people have had similar issues. unfortunately getting other logic boards to test with here in Australia is quite expensive to the point I can't afford so I'm hoping some of you here can help me out with working on this problem.
btw im an engineering student, and yes I've done the recapping etc etc
