It depends upon your skill and comfort level. It also depends if you mean analog board or logic board. I would feel quite confident in my skills and the risk level for replacing the logic board, but not the analog board.
It was once easy to solve that by going to your local Radio Shack and picking up alligator clips; however, it is not so easy now. As such, I would consider ordering cheap online or if you are on a tight time table other stores should have something. If you just want to swap the main board, know the risks are lower for that than the analog board.
Thanks i have got the hang of it and now i am able to confirm that the Logic board is the cause of the problems the machines having! Thanks you were a big help!
