I replaced an ailing HDD in my 1400c with the SD card adapter pictured. From my research it should work, but it doesn't. Trying multiple SD cards of different types (cheap class 4 to SLC industrial class 10) with the OE 7.6.1 install CD, the OS can see the card and gives the correct size but always fails to initialize it.
"Initialization failure," repeats after restarts, re-seats, and SD card changes. Sometimes the OS doesn't see anything on that bus but that's less common.
Is there a brand or eBay seller with adapters that are known to work in general or specifically to the 1400?
