Connecting LED to replacement hard drive
I had to replace my original SE/30 HD with an Apple SCSI 250mb drive made by Quantum (Quantum Prodrive LPS). How can I connect the LED to that new drive so that I can show HD activity?
There should be a connector near the end of the drive for the LED, most likely labeled "LED" (but not necessarily).
On my drive, I had to gently bend the pins up to make enough room for the LED connector to fully seat on the connector. Also, do a quick power on test before reassembly. That way you will know if you have the polarity correct or if you need to flip it around.
