color monitor for the apple ///
Very cool. That needs a special card for that, no? The rest of the pics are great too. Thanks for sharing.
One other off-topic question. Does the Profile cable have the center pin missing on the top row of the 25 pin cable? I've been trying to revive a couple of 5MB Profiles but can't seem to low-level format them with a Zilog Z8603 (with proper ROM) and BLU on a Lisa 2/5 or 2/10 with a parallel card.
Thanks.
I don't think so... that comes right out the back of the ///. The IIe required an RGB card.
Then I'll feel free to butt in. ;-) Yep - mine does.
I didn't know you could LL format without formatting software on the /// (in addition to the chip)...?
Apple /// has built-in colour, better colour than the Apple II!
Unfortunately, the Monitor /// that matches the Apple /// is monochrome, and apple never built a matching colour monitor :-/
Thanks for the info. Now I remember why I was looking for one for so long. I totally forgot why :) I recently bought a Apple Color Composite IIe and thought I was done because I thought I was looking for one for a IIe but I guess not. It was the Apple /// I was eyeing it for. Th ey are pretty rare.
@david__schmidt Yu can read more about BLU at http://sigmasevensystems.com/BLU I've only had it work on a Widget for me but looks like CelGen got it to, at least, format before becoming corrupt. Can't say I've had the luxury of seeing that :)
you could use the monitor 100 on the //e and gs. You have to open it up and change a jumper from 16 bit ot 8 bit video.
inside the Apple color monitor 100 on the main pc bard, almost directly under the neck of
the crt, there is a slide switch labeled "16color/8color. To make the monitor work with the
11gs, set the swith to 8color position, and use the cable provided with the monitor
(svs part# 590-0194A) to connect it to the llgs. This configuration makes all colors
available.
BLU didn't format my drive. The LOS installer did. BLU however can LLF a ProFile if the Z8 and format ROM are present (and a jumper I believe?)
I stand corrected. I have the Z8603 and format ROM/jumper for a 5MB Profile and a Z8613 plus format ROM/jumper for the 10MB Profile but haven't had to format my 10MB Profile. In my case three 5MB Profile drives wouldn't complete the low-level format properly with BLU. BLU did low-level format a Widget drive but it doesn't need any special chips or ROMs.
Celgen, it sounds like you need a low-level format.
I have been thinking of using the earlier version of BLU to see if that makes a difference. One of my drives was a IBM compatible Seagate ST-506 drive that I switched the boards on and this is one of the three drives I couldn't format. Unfortunately, I don't have a PC that has the proper MFM card with BIOS that will allow me to low-level format in DOS to see if the drives would work on a PC.
I'm losing hope on them but the failure in BLU is consistent. Unfortunately, I don't have a Apple /// Profile card in my Apple /// and special software to try that route.
