Color Classic Screws
Hi Guys,
I have a Color Classic here but missing the screws to hold the case together (the back case). Does anyone know the part number/sizes so I can get some replacements?
Thanks
I pulled out a case screw from my color classic, they appear to be a pan head T15 M4 x 1.75 x 16:
  • Diameter of the head of the screw is 7.8mm
  • The fastener uses a T15 (Torx)
  • The nominal diameter of the thread is 4.09 mm
  • The thread pitch is 1.75mm
  • The threaded length is 16mm long
Hope this helps anyone else who needs replacements. I also found this on Home Depot, it's Philips and the thumbnail doesn't appear entirely accurate but it may help.
