Hi gang!
I recently pulled one of my old project machines from storage after ~10 years. This is a Color Classic that I long ago upgraded to a Color Classic II motherboard, 36 megs of RAM and a PDS Ethernet card. I was delighted to hear the chimes and watch it boot to System 7.5.5 on the first try yesterday, and everything was working great... for a little while. After confirming that the machine was working well, I hooked up an old LaCie ZPF SCSI drive to the external SCSI port and powered it all back up - no problem.
HOWEVER.
After that, every time I power up the CCII, it either tries to boot from that LaCie drive (if it's connected / powered on) which fails due to incompatible system software, or (if the LaCie drive is disconnected / powered off) I just get the blinking ? of doom from the internal drive. I can hear the internal drive spinning and going through its power-on routine, but otherwise I can't get it to boot from the internal HDD.
I do know that the PRAM battery is totally shot - is that likely to be behind the issue I'm seeing? Any other thoughts? Zapping the PRAM hasn't helped resolve it yet, so I might pick up another PRAM battery just in case....
HOWEVER.
