I have debated about using an Apple IIe card on my LC for some time but am thinking now that I may wish to use it on a Color Classic instead (in case I ever get another video card for the LC).
A few questions about this card:
1. What version of Apple IIe card software would I need to run this? I'm not sure off the top of my head what is on the disks I have but since the Color Classic needs 7.1 as a minimum would I be able to run it on there? (I for some reason remember 6.0.8 being on Apple II card disks of years past).
2. Can I use the internal 3.5" drive as "drive 1" for my virtual Apple II or do I need to plug the external drive into the "three-headed connector" that goes on the back of the card? (If yes, can it be chained with a 5.25" drive a la Apple IIGS?)
3. If I wanted to print, am I restricted to what type of printer I can use? (I have a Color StyleWriter 2400 that would fit nicely on the platform I'm thinking of using the Color Classic on).
4. Do you folks feel the Apple IIe card is a better option than an actual IIe? (I ask this because I need to use a 3.5" drive with some new Apple II software I just ordered and I'm not sure if I could plug the 3.5" drive into the actual IIe given the drive card I have on there--it's the one that was always used for 5.25" non-Disk II drives).
I have not seen a IIe card in action in nearly 16 years so my memory on how they function is a bit fuzzy...but with two exciting Apple II programs on their way (just ordered them today) I want to make sure I have the optimal system to run them on!
