I have two older Macs (PPC7600 and G3 B&W) that I want to network. The PPC7600 is running OS 7.5 and the G3 is running OS 8.6
I have both HD's named and set for sharing. I have the two machines connected with a crossover cable via ethernet and Appletalk/TCPIP set for ethernet. Both machines have FS turned on.
Problem is evidently they can't "see" each other to connect using Appleshare in the chooser.
Footnote - I also have an iMac which connects fine to the G3 and also to the PPC7600. Seems the G3 doesn't like the PPC7600. Does anyone have a suggestion?
