Greetings everyone, I hope I'm posting in the right place. I've been looking around the internet for help with an issue I've been having, but can't seem to find anything related to my exact problem. All the examples I'm finding are a fair sight more dramatic.
In any case, I have a Macintosh SE, which I got from a college about 15 or 16 years ago when my father was redoing their network and they were just going to throw away a bunch of their old macs. The system was in amazing condition, comes with the zip up carrying case and all the books, really nice. When we moved it ended up going into storage (climate controlled inside storage, so not just like a shed or something), and recently I got it back out to play around with it.
And that's when I noticed the smell. A faint... mechanical smell is coming from the inside of the case. It doesn't really smell like it's burning though, just sort'a.. machine like. Like how some automotive or electronics stores smell? It's hard to describe. Kind'a metalic and musty. The system seems to run perfectly fine, boots really fast, runs like greased lightning (they had it expanded, so it has like 4MB of Ram and a 20+ MB HDD), it just... smells odd. All the time. Even when turned off if you sniff any of the vents you can smell it, but you can smell it even more when it's running. There's no smoke, no vertical or horizontal OMG I"M DYING lines on the screen, just an off smell.
So yeah. I turned it back off and packed it back up, since I didn't want to just keep running it if I might be killing it, and I've been trying to find an answer. Does anyone here know what it could be? Every similar instance I've found online of a Mac SE smelling weird also has screen lines or preformance drops or flakey behavior, which mine does not. I think this may have even been how it smelled 15 years ago when I was first using it, because the smell is familier, but I can't remember for sure. I don't want to plug it back in if I might be frying it.
Thanks in advance for any advice or answers. I was looking forward to messing around with the thing. Sorry about the wall of text, I wanted to be specific.
- On an unrelated note, anyone know how to check the max capacity of the HDD on the mac SE? The finder will tell me that it's currently using 17 meg-ish, but not out of what. So I'm not sure how much more space I have. I looked through the users manual but couldn't find anything.
