This Classic II has vertical bars with no chime after a recap, rework and washing in an ultrasonic cleaner. The bars are present whether the ROMs are installed or not.
The reset button does work. It'll just blip for a moment and display bars again.
This board is the 2-ROM version. I've been testing using the 4-ROM schematics and figuring out the differences as I go.
Voltage rails are fine and the system works okay with a known-good board installed.
Everything in the voltage regulation / ADB page checked out okay except U2 pin-1 to +8v. There was no change to the symptom after fixing that.
The initial routes from every pin of the on-board RAM are okay.
I've started to test the rest of the address paths, but it's slow going.
Have any advice for where to focus troubleshooting?
