Classic II screen replacement.
falen5
I have a classic II with a broken CRT.
Just wondering if the screen from an SE would be ok to replace it, or are there differences.
I know that the 128K screens are different from the rest.
Not sure about the rest of the models.
You can use any Compact CRT, basically they will fit.
Main difference is in the Yoke area, but swapping the yoke by using the original one will do the trick, done a hundred times without any issue apart from minor adjustments.
