Classic and Ram
bibilit
68030
Just scored today a very nice looking Classic, not too yellow,in working condition (there is no HD but was part of the deal) and free ! :)
Boot to the blinking mark, so at least i know that the logic board is ok and screen side is fine as well.
Nice addition, the compact is supplied with one of those anti-theft ring (never get one of those)
I also collected a set of 2 x Sdram 512 mo PC 100...those are unfortunately ECC and probably won't fit any Powermac G4.
I also get the perfect tool (not free this time) for any Compact :
Was used immediately to get the Classic opened, i cleaned the floppy drive and removed the battery (was dead but hasn't leaked at all...was not a Maxell one)
The Classic is only supplied with on board Ram, no additional ram board is supplied...doesn't matter i have got something in mind for this Classic.
Nice score, clean, working units are always nice finds!
Strage it doesn't have the ram board. All Classics i have come across ever, have had the ram board.
I think i have extra ram board with ram inserted if you're interested, PM me.
Hi,
Already have a Classic with the ram board, so won't probably need another one right now, but thanks anyway.
Strange it doesn't have the ram board.
The Classic was sold as a Low-end Compact with only 1 Mb of memory and no HD (and was sold for $ 999) while the $1,499 model featured the memory expansion card and 40 SC hard disk...don't know if this is the Low-end model or if both the expansion card and HD were removed before handling it to me.
Anyway, i can't complain. :)
Hi,
Some news of the Classic.
Some weeks ago i found a broken Classic II :
viewtopic.php?f=3&t=18135
it was a mess... but managed to remove all that can be saved, except for the casing and screen.
I cleaned the board, tested the HD and stored everything in a closet.
Then i collected a Classic,minus HD but in working order...so the easy upgrade was to swap boards and use the working HD:
The only modification required was a small hole in the rear casing.
I already have a Classic anyway, and will keep the Logic board as a spare, now i have a Classic II...well sort of, as the casing is still showing the Classic label.
