I still had a pair of non-working Analog boards (early ones) the design is slightly different from the late ones.
https://68kmla.org/forums/index.php?/topic/31279-dp4-on-classic-ii-analog-board/
https://68kmla.org/forums/index.php?/topic/31245-low-voltage-classic/
Both of them were not working at all (no outputs from the secondary side where new caps have been replaced )
These boards have a Zener Diode (18V) on location DP1 (just above the TDA 4605, location IP1 in the picture below)
In the first board, replacing the Zener solved the problem (i replaced also the diodes DP3, DP4 and both capacitors at the same time)
The second one didn't worked first time ( voltage at pin 6 of the TDA was a bit better with the new Zener, but still below the 12 volt range)
DP3 and DP4 were replaced also and the two caps, nothing else was apparently bad.
In the end i replaced the TDA 4605 also, and the Classic worked (the logic board is shot, only use for testing purposes)
So, all these parts can be responsible for Analog failures.
