Hello all, long time lurker, first time poster.
Like many of you, Ive been trying out the super-cheap radius pivot color card in my SE/30. Ive ordered a TwinSpark card, but who knows when/if it'll arrive. besides, i'm pretty sure it STILL wont fit. so what to do?
My solution might not be the most "proper" out there, but it'll get the case back on.
Here are the Digikey parts you'll need:
1x A32826-ND
1x A1289-ND
3x 1528-1379-ND
Assembly is simple, and tedious. you'll need to push each plug with a pick to ensure tight contact.... Do this properly 240 times and you're all set. tape it up to keep it tight. no soldering involved.
It's probably not the most durable extender, but allows you to bend and twist those cards in any way you can make them fit. It would probably be a good idea to back your cards with Plexi or something.
Some of you might be worried about interference and the like. Ive not had any issues in the few days I've run it, were only dealing with a 16MHz bus to begin with, it'll survive the 8 inch trip. I've worked in industrial electronics for years, and have seen busses like this wide open in racks on 6 foot cables.
1x A32826-ND
1x A1289-ND
3x 1528-1379-ND
