Okay so here's the current situation, I cannot install System 7 onto the CFPM after partitioning/initializing it with a patched HD Setup. It gave an error twice about not being able to write to it in my PB180c and my PB100. I popped in my disk tools and ran first aid. And sure enough, "Macintosh HD is damaged and cannot be repaired".
I tried silverlining and it froze while selecting the disk. I have not tried lido since I did the format in a super complicated matter involving a small ramdisk and swapping the HD out when the system was sleeping (that most likely is what killed it, I wouldnt be surprised and I take full blame obviously it was).
Would anyone be able to make some sort of boot disk img with a super light system 6/7 install with lido or whatever tool you use to format non-apple drives? Extreme kudos to anyone that can. All I have is a windows machine to write floppies atm.
Small tidbit, the drive is 2gb in size. Would that matter?
