So, like a novice woodworker, I didn't measure twice, cut once, so to speak...
I bought a bezel for the second CD drive on my G3 MiniTower, wanting a nice flush look to it. However, the top-of-the-tray clearance is too high to work with the bezel:
As the phone pics aren't the clearest, the OEM CD-ROM of the era cleared (at the top, measured from the bottom of the whole drive) at ~35mm whereas my PlexWriter tops out at ~40mm. Does anyone know of IDE/PATA CD-Rs that don't go above that 35mm mark? Or is it the hardware nature of the beast that they can't be as low profile (the guts I mean) as a CD-ROM,? i.e. is every CD-R of this era going to have similar physical dimensions?
Thanks
Thanks
