nah, just some cheap 1024x768 vga monitor picked up from a thrift storeThat LCD monitor stand has some serious NeXT Cube vibes going on.
Thanks! I have 3 of those Yamaha CDR Drives. I’ll give Astarte a try.
What are you recording it with, software wise?well, to continue with this thread, i got a plaintalk mic in the mail (yes it's the clear one with the long mono plug) but when i record sounds from the mic and play them back, there is no sound. the mic icon shows it's recording something, but nothing is being played back
there is a video file too but for some odd reason mojave won't allow it to play properly, just a white screen
View attachment 53668View attachment 53669View attachment 53670View attachment 53671View attachment 53672
Daft question, is the sound turned up? Does it quack if you click quack?
yes it does, and i found out that if i save the file using simplesound in the applications folder, it worksDaft question, is the sound turned up? Does it quack if you click quack?
That's a control panel, not an application. It's just the sound settings manager. But it should still work.the built in sound app
Ah, you found it.using simplesound in the applications folder,
