Are you familiar with the "Apple II disk server" website? If all you're looking for is some DOS/programs for your IIe that has a working floppy drive the .wav files stored there are an absolutely brainless way of generating disks, that only requires a single audio cable between your cassette jack input and your computer. (Or phone/tablet/whatever; I've been using the site with my old Samsung tablet to generate disks for my ][+ and it works *fine*.) Assuming you're fine with one-way data transfer this is a perfectly good way that'll work even if the cassette *output* of your IIe is broken in some way that prevents ADTPro-over-audio from working.Okay. I know I started this topic a while ago and badly but I'd like to again try to write a 5.25" floppy in ProDOS format. The problem is, though ADTPro can download ProDOS fine onto my IIe (i.e. its receiver cassette port works fine), the IIe doesn't seem to be able to transmit a request for anything (i.e. problem with the transmitter port), so I can't for instance write disks (it's been a while since I've tested this but that is my recollection).
