I’m restoring an SE that has two 800kB floppy drives. One drive barely reads/writes. its head is probably out of alignment. The second drive reads just fine but corrupts whatever disk I feed into it. With the help of my Centris 650, I was able to is install System 6.0.8 on a hard drive image file managed by a ZuluSCSI device.
I’d like to go floppy-less. Will my SE throw a fit if it cannot identify a floppy drive on boot up? Are there any applications or utilities that absolutely require a physical drive?
Assuming I can run the machine floppy-less, is there a way to mount floppy disk images on the SE with System 6.0.8 so I can install software from Mac Repo and Mac Garden?
Thanks!
Thanks!
