Can I format a HD in a 7600 and swap it into an SE/30?
ben68
I have a working 7600 and an extra SCSI drive. If I disconnect the existing 7600 HD and replace it with a non-Apple SCSI spare, will the 7600 prompt me for a system disk? Can I use a 6.0.8 system disk to boot it up, set up the HD then take the HD and put it into an SE/30?
Thanks.
should be able to boot into 7.6 on the 7600 and install 7.5 or 7.6 onto the drive, just do custom install so it will boot onto any mac supporting those OS'es.  You can always remove unneeded stuff later.
