Build your own Raspberry Pi compact Mac!
johnklos
68000
Someone decided to put together a parts list and 3D printer files for a compact Mac based on a Raspberry Pi and Mini vMac:
https://learn.adafruit.com/mini-mac-pi/
While the resolution of the screen is only 320x240, it scrolls so it can support a higher resolution. The screen is color and the emulation can support color, too. Sound and networking isn't working yet, but people can get that working with a little effort.
7" screens that do 800x480 which cost around $40 USD can be bought on eBay. A 4:3 display would be more authentic, but I can't seem to find any that are cheaper than $50 except for ones driven by composite video, which would be blurry. For about $65, though, an 8" HDMI display which does 800x600 can be bought, but then it'd hardly be any smaller than a real compact Mac. Maybe a full sized, but flat compact Mac would be cool?
At 5", composite won't matter as much unless you're picky and trying for RGBi connection or are going to use B&W only mode like classic Macs.
I would like one as well. Maybe one styled like SE or SE/30, I like the ribbed front. Make the drive slot work for SD or micro SD card?
I want to build one before. I have compiled mini vMac on my odroid u2 arm board. The board runs way much faster than RPI. It is as tiny as a credit card.
However, it is hard to build a case. The case in the link is really ugly.
I wish I could do a CAD or download a 3D scan model which use my Xbox camera.
Anyone interested in this project?
Are you able to run non-widescreen resolutions with the Odroid?
I bought a Odroid U3 a few months ago, for my arcade cabinet project (with a 5:4 resolution flatpanel), but couldn't get a standard 4:3 or 5:4 resolution with it.
The tech guy on the Odroid forum told me there's no fix for that: the board can only run widescreen resolutions.
Other than that, the power of the Odroid is incredible, and does blow away the Raspberry Pi by far!
