As I said in the topic about the PowerBook Duos, I was also given two Zip drives with the bunch of Duo bits, one SCSI and one USB. The front bit of the SCSI one is loose though, and a piece of plastic inside is detached. Looking at the USB one for comparison, it looks like that bit of plastic should be attached just above (ie towards the back of the unit) the circular bit that is under the transparent window on top of the drive. It looks to be attached by a spring, which has presumably come loose in the SCSI one. I was just wondering whether it's possible to rectify this, as a SCSI Zip drive would be useful for old Macs (I already have a Parallel one, so would have the full set if this one was to work again
). I can't even see how you are supposed to go about opening it up, as I can't find any screws on the outside at all - anyone know? Thanks
