Hello there,
I have a feeling this is a relatively simple setup issue, but not having a lot of luck figuring out what I'm doing wrong.
I am attempting to boot a Mac Plus using an external SCSI2SD. Specifically, going from the 25-pin connector on the mac plus to a 50-pin centronics, SCSI2SD is in an external enclosure connected from that centronics to a 50-pin connector. There is a terminator pack on the second centronics port of the enclosure, I tried it with this both on and off.
The SD card has an install of 7.1 which boots successfully on an SE and an SE/30 with the same setup. I am powering the SCSI2SD through the USB port, although this was not needed on the SE and SE/30, it was able to run on termination power.
SCSI2SD is configured as id 6, and termination is turned on in the setup.
Basically on the Plus, it turns on, chimes, and stays on the floppy/question mark icon. I do see a single flash on the LED a few seconds after the Plus powers on, but that's it.
This is a SCSI2SD 5.2. Also have a V5.0c that I tried as well, same thing.
I feel like there is something fairly obvious that I'm not doing here, just not sure what it is. Any ideas? Thanks very much!
