Just that. I've been bitten by the UNIX bug and now I want a good ol' terminal on my Mac.
And preferally one which can run Mac applications as well.
What he's referring to is using a minimal kernel + miniroot environment to do the installation onto your hard disk over a network, verses having to create floppies or CDs with the full file set on them. NetBSD is very good at installing from a network as long as you can get the miniroot environment loaded "somehow", be that via floppy, BOOTP, etc. I've found it a godsend for installation on ancient machines even when they have CD-ROM drives because most of those old drives have issues with modern CD-R media, which makes hard to burn a full installation CD that works.it's going to have to be very minimal if you want to run from a floppy.
Correction: It's a lot easier if you have a floppy drive (I don'tIt is a lot easier if you have a network card (as you can do a "single floppy network-based install,"
I've got a hard disk nowit's going to have to be very minimal if you want to run from a floppy.
Manual. But the bottom head cracked after I dropped itHmm, you've gone from no hard disk to no floppy.
Is your drive manual inject or auto inject?
c
