So the stock Toshiba from my G4 iBook took a dump on me. It will try to boot, then go black and turn off over and over again. Did verbose mode, and it was throwing an internal IO problem, then it couldn't mount disk0s3. I booted from my Leopard install disc, and tried formatting the drive, it errored out on me. Plugged it into my adapter from OWC to my MBP, tired formatting it in Mountain Lion Disk Utility, same thing. So, its time for an upgrade. Any good ideas? I know the heat from a 7200rpm drive will warp the plastic, but what about a 5400rpm? Or should I try a compact flash card?
