Beige G3 bootable from SCSI??
Quadraman
68030
My two beige G3's came without hard drives but I don't have any IDE drives to spare to put in them. I do have a lot of SCSI drives, though. Can the G3 boot from a SCSI drive connected to the internal SCSI bus?
I seem to remember hearing that the Beigey's built-in SCSI bus is very slow though, it is only really meant for Zip drives and things like that where high performance isn't needed.
I can confirm that they can boot from a SCSI hard drive, as my beige G3 tower had only a 2GB SCSI drive in it when I got it.
actually if you have a revA beige G3 it will ONLY boot from SCSI.
SCSI was the primary boot bus on all the first-gen G3's.
Wrong. I've got a rev A (brand new from the factory in 1997) that booted just fine with it's 6 GB EIDE hard drive and no SCSI hard drive.
SCSI is the secondary boot device on all Macs with built-in SCSI. The primary boot device is the floppy.
Peace,
Drew
Beige G3s had 6GB drives as standard back in 1997? I thought they were only 4GB!
Either way, thats pretty damn huge for 1997...back in December 1997 when i got my PB1400, it had a 2GB HD...and i remember i was so sure that i would NEVER fill it up. :p
i think the Beige G3's internal scsi bus runs at 10mb/s and the external scsi connector ( i think ) is limited to 5mb/s. i could be a bit off on the external scsi. i know the onboard IDE on all Beige G3's is capable of 16mb/s even its not allot in the speed area you can tell a speed increase if the HDD will use all of the 16mb/s bandwidth of the onboard IDE. altho it does pail in comparison to a ATA 33 IDE bus , but the IDE speed on the Beige G3 is still capable of doing allot of things, but it is still a bottleneck when compaired to a faster IDE bus.
if you do get a IDE drive the Beige G3 can see and use up to a 128gb HDD, and even the full amount of a larger HDD if you get a PCI IDE controller card ( some have the same 128gb limit and some can see larger drives. but then you run into the question is it worth it to put the money into a Beige G3 ( it would depend on who you ask) every one here has a opinion on what Mac is worth upgrading.
when you do upgrade a Beige G3 it is still a very capable system but still lacks the performance that a newer model Mac has even when you upgrade it to the max
There's only one SCSI Bus on the Beige G3 that has both internal and external connectors. It runs at 5MBps.
You may be confusing it with the PCI Power Macs all of which, except the 7200 had two busses: a 10MBps Internal Bus, and a 5MBps Internal/External Bus.
Although the IDE Bus claims to be 16MBps, a 5MBps SCSI bus with just a fast hard drive will outperform it slightly due to overhead issues (sort of like FW 400 kbps being twice as fast in the real world as USB 2.0's 480 kbps)
Note the use of big B and small b. Big B = 8 small b.
Maccess is right. There is only one SCSI bus in the beige G3, and it runs at 5 MBps.
Peace,
Drew
Sure did.
http://docs.info.apple.com/article.html?artnum=112427
6 GB in 1997 really wasn't huge. I remember people having 10 GB drives in their PCs.
My first PC only had a 1.2 GB drive, and that was bought right at the start of '98! Added an 8 GB drive a year or two later, I still remember thinking how enormous that was and how I couldn't possibly ever fill it up! Now you can't even fit the OS inside 8 GB, let alone anything else...
My G3 is a late '98 model and had a 10 GB drive inside it though (Apple-logoed, so probably original) - that would have been pretty huge back then. And it had the 300 MHz processor and 640 MB Ram (though some of that must have been added at a later date, though it would still have had a lot more than the stock 32 MB when it was new, considering what it was used for) - makes that 233 MHz P1 that I had back then look very un-impressive! Just a shame I didn't have the $3,000 that G3s cost back then (plus whatever the extra memory cost) - my first PC didn't even cost half that, and that included a screen and printer!
Ok now my only question is will I be able to install a non-Apple drive and will the 9.2.1 CD format and install to it?
It would've been...when i got my iMac in 2000, it had a 6GB HDD, and i remember i was so sure i'd never fill that up either.
Someone mentioned here that the requirement for Apple ROM drives was removed when IDE was introduced. I was certainly able to install a non-Apple IDE drive into my B&W. Not that that helps as a B&W is newer than a beige not to mention I installed OS X and not 9 (not even with Classic though I might consider it after I get my G4).
IDE drives are fine, I've formatted non-Apple ones using Drive Setup on OS 9 in my Beigey. If you're talking about SCSI drives, then just use Silverlining or something like that to format them.
No, use Drive Setup. If Drive Setup fails to recognize the drive, then resort to a third party app.
For what it is worth, I've never had Drive Setup not recognize a recent model SCSI drive. I've used it to format drives branded by Compaq (actually Seagate drives, but whatever), IBM drives, Connor drives, Quantum drives, and many a Seagate.
Peace,
Drew
