Battery Charge
benjgvps
I have been using my PowerBook 150 A little more and I think I'm killing the battery charge. I have to plug it in for a second to get it to start (The pram battery is dead) and I sometimes plug it in when the charge is around 50% (Sometimes more). By the way the battery is an after-market NI-MH battery which has done me very well so far. I just want to know any tips on keeping this battery alive. I also want to know if I could somehow (Or somewhere) get the pram battery replaced because it is very annoying to have to find a plug to turn it on.
NiMH batteries aren't quite as bad as NiCD with the dreaded "memory effect," but they do suffer from it. Usually, totally draining the battery until the computer sleeps on its own and then plugging it in overnight to completely recharge will help to reset the cells so that they "remember" their full charge state. You may have to do it once or twice initially to get it back to normal, then about once per month or so afterwards as maintenance. Batteries don't last forever, though, so if it keeps going downhill, you'll probably need to buy a new battery or re-cell your old one.
As for the PRAM battery, on the PowerBook 100 series (except the 100 and 190), it's a little rechargeable button cell roughly the size of a quarter. It's got little tabs spot-welded onto it, which are soldered to the intermediary board mounted in the top half of the case (the board that interfaces the keyboard and display to the motherboard via that large IDE-looking ribbon cable). It's not too hard to replace, so long as you find the proper battery to replace it with. I don't have any 100-series machines to play with now, so one of the other forum members can probably help you with the specifics.
