Basilisk II Question
equant
I tried to find an active Basilisk community to ask this question, but it looks pretty sparse out there.
Does anyone know how (or if it's possible) to toggle out of full screen mode? Specifically using the linux version, but I'd be happy to learn if it's possible (and how) on any system running Basilisk.
Thanks,
equant
Well, using the windows version alt-enter did the trick but I can't say the same for any other platform.
Thanks russman. I'll try it.
Also, anyone know what key maps to the option key? Alt appears to be the command key.
Thanks
In the Windows version there's a setting to make it run in a window but no idea whether you can toggle in/out. And as for the Linux version... :?:
Yeah, linux lets you choose before "boot" whether it's full-screen or in a window. alt-enter doesn't seem to do the trick under linux.
