Aztec LC PSU still ticking after recap
CompuNurd
68000
I just recapped an Aztec PSU from a Mac LC, and when I go to turn it on, it just ticks. The solder connections look fine, is there something I am missing?
The voltages I am getting are: ~4.5 from the blue wire, ~1.25 from the yellow wire, and ~.60 from the orange wire.
What's it supposed to read? My meter has the diode and 2Kohm functions together. When I measure, the reading is ~.200 then rises up to ~1.700, and keeps going.
Then there are no shorts on the rails.
So, as long as the power supply is connected to a load, it should run. You may need to change the opto-coupler.
I have tested the optocoupler and it seems to be fine (unless I tested it wrong?).
I guess it never hurts to try. The model is CNX82A, Mouser and Digikey do not stock it, but I found some on eBay.
The optocoupler seemed to fix it, but there was a humming, presumably from the transformer, and a lifted pad. I don't trust it, so I will be scrapping it.
It was audible from several feet away. If you want it, I'll send it to you for the cost of shipping, shoot me a PM. Better someone make use of it than it being trashed.
